How to join and dissalow join different elements
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
dataEnteringNode = IN
elementA = UnwrapElement(IN[0])
elementB = UnwrapElement(IN[1])
results = []
#Unjoin
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.UnjoinGeometry(doc,A,B)
result.append(result)
except:
pass
#Join
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.JoinGeometry(doc,A,B)
except:
pass
#Switch Join
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.SwitchJoinOrder(doc,A,B)
except:
pass
OUT = results
please i will join structral elements and dissallow join non structural elements
See also following topic:
hello
i adjusted the title
You need to instal the Hotgear package
it has a lot of nodes for join etc
Auto Join without Order.dyn Please do not work
Capture2
the nodes from hotgear are working
I didn’t find These fields
Modify it to achieve this
I’m sorry to waste your time
sdfzeeaz
Goodmorning
i adjusted your script
join - unjoin-switch join order Geometry.dyn (24.3 KB)
Goodmorning
I regret it did not work
https://drive.google.com/file/d/11m8qkRGb1_zI6LI9KCAtGFbtRdjsENoK/view
it depends on the way you use it probably. one time run goes great. two times not. thare for you need to restart dynamo.
But now i put a toggle from the Rhythm package. you can run it as much as you like.
join - unjoin-switch join order Geometry.dyn (26.4 KB)
I’m still sorry the problem
Once again Thank you
in my case it works
i put all 3 options in one script
you have to run one option and delete or freeze the other 2
have Revit 2018 and Dynamo version 1.3.2.2480
What version off Dynamo do you use?
my version Revit 2017 and Dynamo version 1.3.2.2480
Works only SwitchJoin.Geometry For one column
