Multiple Join Elements...again
Dear all,
I’m starting at Dynamo and Python.
I found a script (https://www.youtube.com/watch?v=zSFs47BJtAU) to join multiple elements (walls, floors,…) but I can’t find the error at code
Does anybody could help me?
Regards
Please post the actual code, not an image of it.
@arquiteto.rafael
There’s no space here
and a typo here:
@Konrad_K_Sobon
clr.AddReference("RevitAPI")
clr.AddReference("RevitSrvices")
import RevitSevices
clr.ImportExtentions(Revit.Elements)
dataEnteringNode = IN
elementA = UnwrapElement (IN[0])
elementB = UnwrapElement(IN[1])
results = []
for A in elementA:
	forB in elementB:
		try:
			result = Autodesk.Revit.DB.JoinGeometryUtils.JoinGeometry(doc,A,B)
			results.append(result)
		except:
			pass
OUT = results
Finally I found all type mistakes and it’s working.
Thank you all!
Is this correct? it does not seem to be working…
Try the CombineElements() method in the Document class, it’s more suitable for this kind of operation. Plus, it’s better as you can input a list of elements rather than two at a time, so no loop (or the overhead) is necessary.
