Joining/Unjoining Tool
Good morning everyone,
I am using dynamo in order to accelerate the process of joining elements.
I have several hundreds of structural framing, structural columns and floors that I need to join in order to avoid double concrete volumes in schedules.
In this video I have found a python script that does what I want, allowing me to join, unjoin or switch join order for a certain group of objects.
The problem is that I am dealing with a really large quantity of elements, this is why I want to apply this definition to group of elements that do not necessarily intersect. This leads to a massive amount of warnings.
Thanks to the “does intersect?” node I can get where I want in terms of lists: for example, I would have a list of n floors and a list of n sub-lists in which all the beams intersecting each floor are contained.
Obviousluy the python script won’t work with this list structure.
I know that there might be alternative solutions to my problem (like solving the warnings in a second moment or other) and I appreciate all kind of suggestions, but I really want to improve my python skills.
For this reason I would like to ask how can I adapt the scripts shown in the video in order to get there.
I think this can be useful for many people: there are several python scripts out there, they can be applied to a single set of elements but they don’t always work with sublists.
Thanks in advance!
This is the code of the video:
clr.AddReference(“RevitAPI”)
dataEnteringNode = IN
elementA = UnwrapElement(IN[0])
elementB = UnwrapElement(IN[1])
results = []
for A in elementA:
for B in elementB:
try:
result = Autodesk.Revit.DB.JoinGeometryUtils.JoinGeometry(doc,A,B)
#The function on the previous line can be replaced with SwitchJoinOrder or UnjoinGeometry.
results.append(result)
except:
pass
OUT = results
I haven’t used this code before so let me make sure I understand everything…
Normally you would input one list of elements to join with another list of elements. You want to input one list of elements (floors) to join with a list of sublists of elements (beams), but this doesn’t follow the same list structure.
If this is the case you just need to modify your for loops a little bit. If your floors already align with your beam sublists you can iterate through them together. Try for A,B in zip(elementA,elementB): instead of separate loops for A and B. Then you can have another for loop for each beam within the beam list B.
Try creating a custom node with the python. With minimal effort you can then make use of not only lists but also lacing and levels.
@jacob.small’s suggestion is definitely the easiest and most straight forward approach.
However, if you want to improve your python, it shouldn’t be too difficult to get your list structure working.
Thanks to both of you, @jacob.small and @Nick_Boyts.
The solution proposed by Jacob works well, but I will also try with Nick’s suggestion.
