Nice, i think need improve some setting from dynamo core to can do that.
@chuongmep well, works for a lot of packages but open3d threw an error after installign it like that, see Cpython 3.8.3 open3d dll import error - Developers - Dynamo (dynamobim.com)
any thoughts?
I have suggest change to py -3.x -m ..... to install if user have mutiple version python installed in computer.
Great toturial, easy to follow! Got it working within 15 minutes
I was reading through the guide you put together for connecting python modules to dynamo with Cpython3.
I’m trying to use the Anaconda method described by Sol so that i can use the scikit-geometry module.
many packages installed with Anaconda are recognized by dynamo, such as numpy, scipy, pandas.
import sys
sys.path.append(r'C:\ProgramData\Anaconda3\envs\Dynamo212\Lib\site-packages')
import numpy
import scipy
import pandas
import matplotlib
dataEnteringNode = IN
# Place your code below this line
OUT = sys.path,sys.version, sys.executable
but when i add matplotlib, i get an unexpected error
Warning: ImportError : DLL load failed while importing ft2font: The specified module could not be found. [’ File “”, line 12, in \n’, ’ File “C:\ProgramData\Anaconda3\envs\Dynamo212\Lib\site-packages\matplotlib\init.py”, line 207, in \n _check_versions()\n’, ’ File “C:\ProgramData\Anaconda3\envs\Dynamo212\Lib\site-packages\matplotlib\init.py”, line 192, in _check_versions\n from . import ft2font\n’]
when i check this in python in the terminal or in VSCode, the modules matplotlib and skgeom load with no issue
stackoverflow suggest this has something to do with the specific version of matplotlib, but @chuongmep seems to have been able to import it successfully without needing to restrict the version, and as stated above, the modules load when running in the Anaconda environment.
I’m pretty sure i built the Anaconda environment from Dynamo’s embedded python, but there’s clearly something different between what gets configured inside dynamo, and the Anaconda environment.
if i open the dynamo embedded python environment (?) and enter the same procedures as in dynamo, the outcome is reproducible
i’m not sure what is different. both are using python 3.8.3
edit - i guess there are vague instructions to install CGAL directly, and then build scikit-geometry
from the article:
i will try this tomorrow
You can try to fix by some solution in this, I don’t recommend use Anaconda to install package.
python - from matplotlib import ft2font: “ImportError: DLL load failed: The specified procedure could not be found.” - Stack Overflow
i guess i’m interested to try and understand what’s different between dynamo’s Embedded Python and what gets configured in the Anaconda environment. It’s a shame it doesn’t work as expected because Anaconda seems like a really nice way to manage packages.
but, yeah, to ‘fix’ it, i’ll try to install matplotlib directly to the Embedded Python with the get-pip method
Hi @mclough - From our side, we essentially embedded Python into the Dynamo ecosystem using this process: Python embeddable zip: install Tkinter - Stack Overflow, which may contain the nuggets you are looking for ![]()
Unfortunately, I do not know why the Anaconda and direct install versions may be different, but it’s worth a read of the above if you are curious.
Hi Solamor
Just read your guide to acess requests package for Python in Dynamo.
This guide helped me alot!
Thanks alot.
You are most welcome @Mainot
Glad it helped!
Hi, I have this warning and don’t know how to solve it.
Could you please tell me what could theoretically be wrong? I installed Python 3.10.8 recently for educational purposes. Do you think it could be problem?
the error says the path of pthFilePath is wrong.
You don’t need to install Python3.10, Dynamo use a internal CPython3 engine
hello,
- EDIT 02/07/2023 : updated code
- EDIT 11/05/2024 : update pth file edition, create dict at output
# More info here
# https://github-wiki-see.page/m/DynamoDS/Dynamo/wiki/Customizing-Dynamo%27s-Python-3-installation
import sys
import System
import re
print('\n'.join(sys.path))
pyEngineName = sys.implementation.name
clr.AddReference("System.Windows.Forms")
import System.Windows.Forms
from System.Windows.Forms import MessageBox, MessageBoxButtons, MessageBoxIcon
from System.Reflection import Assembly
dynamo = Assembly.Load('DynamoCore')
dynamo_version = str(dynamo.GetName().Version)
dynamo_version = tuple(int(x) for x in dynamo_version.split("."))
print('dynamo_version', dynamo_version)
init_setup = False
if pyEngineName != "ironpython" and dynamo_version > (2,8,0,0):
clr.AddReference('Python.Included')
import Python.Included as pyInc
path_py3_lib = pyInc.Installer.EmbeddedPythonHome
import platform, os, subprocess, importlib.util
from System import Environment
from System.Net import WebClient
# get paths
assert os.path.isdir(path_py3_lib)
pipDirPath = os.path.join(path_py3_lib, 'Scripts')
pipfilePath = pipDirPath + "\\pip"
get_pip_path = os.path.join(path_py3_lib, 'get-pip.py')
site_packagepath = os.path.join(path_py3_lib, 'Lib\site-packages')
lib_path = os.path.join(path_py3_lib, 'Lib')
if not os.path.isfile(get_pip_path):
client = WebClient()
client.DownloadFile('https://bootstrap.pypa.io/get-pip.py', get_pip_path)
filepy_pth = f'python{sys.version_info.major}{sys.version_info.minor}._pth'
pthFilePath = os.path.join(path_py3_lib, filepy_pth)
assert os.path.isfile(pthFilePath), "Error file {} not found".format(pthFilePath)
# start update pthFilePath
with open(pthFilePath, 'r+') as f:
lines = f.readlines()
for idx, line in enumerate(lines):
if re.match(r'#import site', line) is not None:
lines[idx] = re.sub(r'#', '', line)
f.writelines(lines)
break
# add site-packages
if re.search(r'./Lib/site-packages', lines[-1]) is None:
f.write("\n./Lib/site-packages")
# end update pthFilePath
# install pip
if not os.path.isdir(pipDirPath):
#print(f'installing pip in local Python environment: {path_py3_lib}')
print('installing pip in local Python environment: {}'.format(path_py3_lib))
subprocess.Popen(["python", get_pip_path])
# try to update pip
try:
subprocess.Popen(["python", '-m', pipfilePath, 'install', '--upgrade pip'], cwd = path_py3_lib)
except Exception as ex:
print(str(ex))
init_setup = True
MessageBox.Show("Initialization in Progress...\nWhen installation finished, close Dynamo and relaunch this script to install packages", "Initialization In Progress...", MessageBoxButtons.OK, MessageBoxIcon.Warning)
raise Exception("close Dynamo and relaunch this script to install packages")
print('pip was already installed for this local Python environment')
init_setup = False
# install packages
installPackages = IN[0]
dict_result = {"out":[], "error_warning" : []}
if installPackages and not init_setup:
sys.path.append(site_packagepath)
sys.path.append(lib_path)
for packageName in installPackages:
spec = importlib.util.find_spec( packageName )
if spec is None:
try:
result = subprocess.run([pipfilePath, "install", '--target='+ site_packagepath, packageName], capture_output=True, cwd = path_py3_lib)
#print('{} succesfully installed'.format(packageName))
dict_result["out"].append(result.stdout.decode('utf-8'))
dict_result["error_warning"].append(result.stderr.decode('utf-8'))
#print(f'error while installing {packageName}')
dict_result["error_warning"].append('error while installing {} , {}'.format(packageName, ex))
#print(f"package {packageName} is already installed")
dict_result["out"].append("package {} is already installed".format(packageName))
# check result
if False:
import numpy as np
import pandas as pd
MessageBox.Show("Installation et Configuration Python terminé avec succès!", "Installation Python", MessageBoxButtons.OK, MessageBoxIcon.Information)
OUT = dict_result, None
elif pyEngineName == "ironpython" and dynamo_version > (2,8,0,0):
MessageBox.Show("Basculer ce noeud sur le moteur CPython3 puis relancer le script!", "Installation Python", MessageBoxButtons.OK, MessageBoxIcon.Warning)
Hello @c.poupin , I have this warning
I fixed the code yesterday (little change), try my last code or change IN[1] to IN[0]
Wow, it works nice after change to IN[0] for numpy, pandas and also for shapely ![]()
Thank you very much.
Helo,
I am getting the following error:
Could you help me out please?
edit: second attempt, worked. thanks
Good afternoon!
Can you tell me how to install the module openpyxl in Dynamo’s Python?
Hello @maksim7747 have you tried this yet? Customizing Dynamo's Python 3 installation · DynamoDS/Dynamo Wiki · GitHub
Also, if you have Revit 2024.2 you will halve it now out of the box ![]()
Добрый день! Да я пробовал это способ. Пункты 18,19,20 не выполняются.
Translation: Good afternoon Yes, I tried this method. Points 18,19,20 are not fulfilled.
