I would like to insert a family on each pipeline of a project.
I think it is necessary to: recuperate the pipes transform them in line. On his lines add points and insert on a point a family?
I have to integrate a slider to wish to insert the family on a point on the left or right or in the middle of the pipe.
Can you help me please ?
Long answer:I’ve thought about this a few times but there’s a series of steps involved that might make it possible, but I haven’t tried it myself. The Revit API won’t allow you to insert a pipe fitting or pipe accessory directly into a pipe so a workaround is necessary. These would be my presumed steps:
Break up the pipe at the point of insertion by shortening the existing pipe
Insert the family and connect with the existing pipe
create a new pipe from the fitting to replace the pipe that was shortened and connect with the fitting and existing fitting on the other side
The problem with the above workflow is that the fitting is always a loadable family and it’s parameters for diameter can vary per family, so you can never be sure which parameter to use. Furthermore the fitting will probably be placed first before the diameter can be set, resulting in auto-generated transitions by Revit which might cause nearby fittings to generate warnings.
