Hi guys:
How to get a selection of multiple surfaces at the bottom border ?
How to fix this ?
Thanks!
TSF-0229-w2-Q1.dyn (3.0 KB)
Hi guys:
How to fix this ?
Thanks!
you may start by extracting the Z vector from the end & start point for each of the curves. let’s assume the " base " is @ 0.00 … so the curves that have a Vector Z = Zero in both start & end point of the curves are the ones you are looking for. give me a bit of time and i’ll post the solution
@Dornan_Luke Check this out.
if your reference which is the “base level” has changed then all you have to do is change the values in the code block {{0,0}}
to match your desired level. & keep an eye on the lacing in the nodes. good luck !
