How to get the stairs of runs and landings?
Hi all,
We are trying to get the stairs of runs and landings.
Just like things in opposite way of topic below
But having problem applying the GetStairs Method for runs and landing, can anyone help us?
GetStairs Method (revitapidocs.com)
# Add references to the Revit API
clr.AddReference('RevitAPI')
# Import necessary classes from Revit API and RevitServices
from Autodesk.Revit.DB import Document, FilteredElementCollector, BuiltInCategory
from Autodesk.Revit.DB.Architecture import Stairs, StairsRun
# Get the active document
# Method to get the parent stairs of a given stairs run
def get_parent_stairs(stairs_run_id):
    # Start a transaction (required for most Revit API actions)
    # Get the stairs run element
    stairs_run = doc.GetElement(stairs_run_id)
    # Check if the element is a stairs run
    if not isinstance(stairs_run, StairsRun):
        raise Exception("Element is not a StairsRun")
    # Get the parent stairs of the run
    parent_stairs = stairs_run.GetStairs()
    # End the transaction
    return parent_stairs
# Example usage:
# Replace 'stairs_run_element_id' with the actual ElementId of the stairs run
stairs_id= ElementId(IN[0])  # Example ElementId
parent_stairs = get_parent_stairs(stairs_id)
# Output the parent stairs
OUT = parent_stairs
There are a few problems with the code:
  • Missing import clr at top of before clr.AddReference
  • ElementId needs to be imported from Autodesk.Revit.DB
Thank you so much Mike, the fixed code and the error message are shown below:
Warning: IronPythonEvaluator.EvaluateIronPythonScript failed。
File “”, line 39, in
TypeError: expected BuiltInParameter, got UnknownElement
from Autodesk.Revit.DB import Document, FilteredElementCollector, BuiltInCategory,ElementId
# Example usage:
OUT = parent_stairs
ElementId expects an integer, if you are say selecting a stair run in the active view you will need to use
stairs_id = UnwrapElement(IN[0]).Id
Thank you, Mike! The Script runs perfectly when inputting a single stair run, now we are trying to make it work when we input a list of stair runs
# Example usage:
stairs_id= UnwrapElement(IN[0]).Id  # Example ElementId
OUT = parent_stairs
Here are the script we are working on now, but both of them aren’t working well now.
def get_parent_stairs(stairs_run):
    # Check if the input is a single StairsRun or a list of StairsRun
    if isinstance(stairs_run, list):
        stairs = []
        for run in stairs_run:
            if not isinstance(run, StairsRun):
            stairs.extend(run.GetStairs())
    return stairs
# Example usage:
stairs_run_elements = UnwrapElement(IN[0]).Id  # List of StairsRun elements
# Get the parent stairs for each StairsRun element
parent_stairs = get_parent_stairs(stairs_run_elements)
OUT = parent_stairs
from Autodesk.Revit.DB.Architecture import StairsRun
def get_parent_stairs(stairs_runs):
    parent_stairs = []
    # Iterate through each StairsRun element in the input list
    for stairs_run in stairs_runs:
            raise ValueError("Input must be a list of StairsRun elements.")
        parent_stairs.extend(stairs)
# Example usage:
OUT = parent_stairs
above script show the message below:
File “”, line 42, in
File “”, line 31, in get_parent_stairs
TypeError: Stairs is not iterable
You are going to have to tailor the script to iterate over the input and decide what format that is going to be - say integers or elements
# Check for list
if not hasattr(IN[0], "__iter__"):
    IN[0] = [IN[0]]
# Id integers
stairs_run_elements = [ElementId(item) for item in IN[0]]
# Selected elements
stairs_run_elements = [item.Id for item in UnwrapElement(IN[0])]
Modify parent_stairs.extend(stairs) line as extend is used to join a list (or other iterable) to a list
parent_stairs.append(stairs)
Here are a few links to help you with your Python and Dynamo Forum experience
How to get help on the Dynamo forums
Dynamo Python Primer
and if you haven’t already I would consider an introduction to python course / book
Automate the Boring Stuff with Python
University of Helsinki Python Programming MOOC 2024
Thank you so much for sharing the learning references!
I will study first, and share the code once I finish it.
