Getting wrong stairs length/width from Python & Revit API
Hi everyone
I have some python code, apparently running ok, to get the horizontal area of two stair runs getting their line boundaries through Revit API. The code seems to be working, but I am getting all lengths multiplied by more or less 3, more or less (default width is 1.00 m and I’m getting 3.28 m).
Does anybody know what could be going on? Thank you all so much in advance
stairs = UnwrapElement(IN[0])
runIds = stairs.GetStairsRuns()
runs = [stairs.Document.GetElement(runId) for runId in runIds]
bounds = [run.GetFootprintBoundary() for run in runs]
len = []
for bound in bounds:
	for line in bound:
		len.append(line.ApproximateLength)
isplanar = [bound.HasPlane() for bound in bounds]
planes = [bound.GetPlane() for bound in bounds]
isopen = [bound.IsOpen() for bound in bounds]
isrect = []
areas = []
width = []
height = []
for plane in planes:
	isrect.append(bounds[planes.index(plane)].IsRectangular(plane))
	if isrect[planes.index(plane)] is True:
		width.append(bounds[planes.index(plane)].GetRectangularWidth(plane))
		height.append(bounds[planes.index(plane)].GetRectangularHeight(plane))
		areas.append(bounds[planes.index(plane)].GetRectangularWidth(plane)*bounds[planes.index(plane)].GetRectangularHeight(plane))
		areas.append('error')
OUT = runs, bounds, len, isplanar, isopen, isrect, areas, width, height
The units being returned are likely incorrect. 3.28 feet = 1 meter if memory serves.
Yes, results are returned in FEET as Revits internal units. You could look for a conversion node or change units in the Python node.
decimal_feet_length = detail_line.GeometryCurve.Length
metric_length = UnitUtils.Convert(decimal_feet_length, DisplayUnitType.DUT_DECIMAL_FEET, DisplayUnitType.DUT_MILLIMETERS)
OUT = metric_length
Thanks Jacob. Dividing the lengths by 3.28 certainly solved the issue, which is interesting because the first thing I did was to check the units in the Revit file and they were in metric system.
Thank you Sean. I tried that and I get the following error: “UnitUtils is not defined”. Is there any module or library I’d need to import?
Here is an example using Revit 2022, but the import should be the same.
clr.AddReference('RevitAPI')
OUT = UnitUtils.Convert(11.7,UnitTypeId.Feet,UnitTypeId.Millimeters)
Keep in mind too that in R2021 the DisplayUnitType was depreciated, and then in R2022 is it replaced by the SpecTypeId, ForgeTypeId and UnitTypeId classes.
