I am trying to get the for coordinates of each room in my building projects (rectangular room) but I cannot manage to do it, can anyone get me a hand?
Thanks in advance
Try searching the forum ![]()
This topic could be an option.
You can use Element.Geometry to get the Room as a volumen.
You could try Element.Geometry on the rooms, get bottom surface , explode into lines,Curve.StartPoint on all of them and you get corner coordinates, for the center one, Surface.PointAtParameters 0,5;0,5 .
Thanks, Johannes, But I am unsure why I cannot fins Level. Plane this node, could you tell me what to search in the nodes library.
are the rooms placed on the level test niveau?
if not then that could be the problem
Did you ever solve this?
Hi there Nachazo
Unfortunatly not…
