Data in excel is limited however in dynamo it appears upto column 5 and row 10. What should I do?
That is really weird, could you share your Excel file? I have never had this problem, maybe try creating a new Excel file. (Just like Ewan said, a list.clean node would also work just fine
Simply delete the unwanted row\columns on excel. I mean not clear the values, but select the columns (letters above cells) and hit delete on the main ribbon tab. This will avoid to import into dynamo empty cells.
