Hie,
I have done a list of numbers and a export of that numbers to excel. The problem is that in excel in the place of one value appears a blank space and i don´t understand why. In the the second column appear 105.27, in the fith appear 108.64 but in the eighth not appear 111.11 and appear a blank space. Somebody knows what happen? Somedody knows how i can check in which list star the value null? I try with the way that i show but it not function.
Thanks a lot.
Round the values before export.
Hey,
Maybe this is useful?
Cheers,
Mark
Hey hey,
replacing nulls by a 0 value should do the trick
Thanks. The problem is that in Dynamo the value exist but in one moment it dissapear. Do yo know how i can locate the item with null value in a list?
Regards
Regards
I can see from the table that the data is offset because of null values. try following the steps in the post links I gave earlier to identify and replace nulls.
Thanks. I think so but i couldn´t find the problem.
Regards.
What happens if you look at the values which are giving the nulls? 2800 or whatever?
Sure, but the value which is generating the null… the 3 values coming from the Math.Round nodes? Are they also null? If so, work back again…
