Hi everyone! I’m trying to find out if it’s possible to get the location (point, xyz) of elevation markers. I’ve found a few threads on the subject but I still can’t figure it out:
This one: the problem is the latest Clockwork package (@Andreas_Dieckmann ) doesn’t have a BoundingBox.ByElements that works like it used to. It no longer results in the marker’s min and max points.
That one: the problem here is that the Python code works for a single elevation marker but not a list of markers.
Any ideas?
The code in the second item is pretty easy to edit to add list handling if you don’t want to make a custom node for it as was shown in the other thread.
Note that I am posting the image so you can go back and edit the code above as a learning exercise, as for loops are a VERY useful python skill.
Just tried out this bit of python code in Revit 2023/Dynamo 2.13 but am getting an error regarding Line 23 for the bounding box.
AttributeError : ‘ElevationMarker’ object has no attribute ‘BoundingBox’ [’ File “”, line23, in \n’].
I’ve tried most of the solutions here (including code to get bounding box of the Elevation Mark by @awilliams) and still have the same problem as @amurrayCD. Any refresh on this topic will be helpfull.
