my code does nothing and it takes a lot of time
clr.AddReference('RevitAPI')
clr.AddReference('System')
elements = UnwrapElement(IN[0])
Inplaced = []
for i in elements:
try:
Inplaced.append(i.IsInPlace)
except:
Inplaced.append(False)
OUT = Inplaced
KR
Andreas
IsInPlace only works for Families. All Elements in Active View collects FamilyInstances which does not have the property .IsInPlace.
Same Python script as yours:
@leonard.moelders ,
it remains empty
in my view there are severial. i got not error
You need to get the Families:
You get no error because of your try-except method
Get the families and it works:
Code:
Inplaced = []
for i in elements:
if isinstance(i, FamilyInstance):
type_id = i.GetTypeId()
fam_type = doc.GetElement(type_id)
fam = fam_type.Family
Inplaced.append(fam.IsInPlace)
OUT = Inplaced
If you are still using your old code you need to have an input like this:
Family not Family Type
Maybe I am missing here something but when I look into the API I can only find IsInPlace as a property of the Family Class and not Family Type neither Family Instance.
