Hi everyone
I want to separate model between created by system and created by model in place(all category).
Revit API can separate it? (all category in one logic)
Thank you
Hi everyone
Thank you
Hi @peerawit.ru,
You can use the Family properties node from the Genius Loci package to filter the model in place with the property IsInPlace.
Clockwork has a node also.
collect all elements and use this api as mentioned above:
https://www.revitapidocs.com/2020.1/eb138fd5-6092-5257-e6e1-073013cb8582.htm
Hi @Alban_de_Chasteigner , @newshunhk
element = UnwrapElement(IN[0])
result = []
for e in element:
if "FamilyInstance" in str(type(e)):
result.append(e.Symbol.Family.IsInPlace)
result.append(False)
OUT = result
From your recommend i think it work.
Thank you.
