my code is a pit off… i want to get From/To Room information
clr.AddReference('RevitAPI')
clr.AddReference('System')
def GetRooms(item, phase):
if hasattr(item, "FromRoom") and str(phase.GetType()) == "Autodesk.Revit.DB.Phase":
exits = 0
try:
if item.FromRoom[phase]: exits += 1
if item.ToRoom[phase]: exits += 1
return item.FromRoom[phase], item.ToRoom[phase], exits
except:
return None, None, 0
else: return None, None, 0
items = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors)
phase = UnwrapElement(IN[0])
OUT = map(list, zip(*[GetRooms(x , phase) for x in items]))
KR
Andreas
Hi @Draxl_Andreas,
I was gonna say you could take a look at the node from clockwork that does exactly what you are after, but I can see now that this is probably where you’ve gotten the inspiration
The code you wrote works if you specify in your collector, that it is only door instances you are after:
items = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors).WhereElementIsNotElementType().ToElements()
Try it and see if it works for you
exits = 0
try:
except:
@MartinSpence ,
it is still weard, i got the code from a book,… at least i should get some Ids ?
I copy+pasted your code and added the line i wrote earlier, and it outputted Rooms.
Do you have Rooms in Phase 01?
@MartinSpence ,
there is only this phase …
this sentence is still weard for mi
The map(list, zip… restructures the outputlist so you get a list with toRoom, fromRoom, counts. So it’s a different way to strcture the output for the node, but not necessary to get an output.
If you leave it out, you will get to/from/counter for each door element:
