Hi, I am trying to use the Element.getparametervalue.byname node but it doesnt seem to read the element type parameters. How can I read and export the Type parameters (grouped in Green) within my script?
19-Exporting Schedule to Excel with Room Update P01.dyn (488.3 KB)
Thank you for your time!
I want to amend this part of my script so that it just reads the elements type parameters.
I cant seem to find Elements.Type node
there are several ways to do it, with or without custom nodes
Elements.type is from Archilab package
It probably shouldn’t be this complicated
Thanks alot Andrew, the Rhythm node worked a treat.
Do you know why the workset parameter shows up as numbers instead of the actual name?
Cheers
The Workset is an element in itself.
What you see is the Id of that element
Hi Marcel, What node would read the Workset for each element in a similar format as shown above?
try this
I’d expect it to be the other way around i.e the value is the name, but that is the way it is
Andrew youre a legend ! Thanks for saving the day !
