Hi
I have multi Structural Framing Elements, I select few elements
Then check Intersection of Elements (this is Start Point and End Point)
How to get pair: Point - Element
Example:
Select 2 element b and c then check element intersect → get: a,d and b,e
How to get Pair: Point -Element
p1-d
p2-a
p3-b
p4-e
Thank Advance!!!
I think this is what you’re looking for?
import sys
all_beam_curves = IN[0]
all_beam_elems = IN[1]
selected_beams = IN[2]
def BeamIntersecter(beam):
# Get Start & End Point
StrtEndPts = [beam.StartPoint,beam.EndPoint]
intersections = []
# For each point in selected curves start end
for point in StrtEndPts:
# for each curve in all the beams
for index, curve in enumerate(all_beam_curves):
# If the start end point intersects the curve
if Geometry.DoesIntersect(point, curve):
# And if the start point of that curve is not in StrtEndPts
if curve.StartPoint not in StrtEndPts:
# Append the point and beam element
intersections.append([point, curve])
# UNFREEZE THE BELOW LINE IF YOU WANT TO RETURN THE BEAM ELEMENT RATHER THAN ITS LOCATION CURVE
#intersections.append([point, all_beam_elems[index]])
return intersections
OUT = [BeamIntersecter(curve) for curve in selected_beams]
You tagged this with Python so I went down that route and assumed you can edit it if you need to slightly change what is being output.
Hope it helps
Hello, you tried if it was possible via bimorph (see link) to see if the category is possible.
From your script after filtering only Points (List.RemoveIfNot) then getting index and GetitematIndex on list elements
Cordially
christian.stan
Awesome!! Thank you<3
But I think need change to list if select 1 element
#create list
if isinstance(IN[0],list):
all_beam_curves = [IN[0]]
if isinstance(IN[1],list):
all_beam_elems = [IN[1]]
if isinstance(IN[2],list):
selected_beams = [IN[2]]
intersections = []
#intersections.append([point, curve])
Great, glad it worked.
Ah yes, I didn’t check it with 1 beam input.
Top tip though, instead of writing out your ‘ininstance’ check for each input, write another function and pass your inputs through it
, something like this:
def tolist(obj1):
if hasattr(obj1, "__iter__"): return obj1
else: return [obj1]
all_beam_curves = tolist(IN[0])
all_beam_elems = tolist(IN[1])
selected_beams = tolist(IN[2])
This uses a slightly different method for checking if the item is a list. Rather than checking if it is an instance, instead you are checking if the item has the attribute of being iterable ("__iter__").
The only reason I used this method over the isinstance one is because it’s the main method I use so I simply copied and pasted it haha.
Hope this helps,
Jake
