I hope you will help me out. Im new in using Dynamo.
In my script, after I gathered the elements (beams) and group them by their coordinates, i want to know if my beam is discontinued or continuous. the way I see it is that if my starting point and endpoint of the beams, have the same coordinates, then its a continuous beam. if the my startpoint coordinate didnt reflect in my end point, then i have a discontinued beam (i use “X” only as my startpoint and end point)
You will need to set lacing of the code block to “cross product”, and then extract the index of paired points. All points that are not paired should have some fake index such as -1. Then, use get item at index node, and group elements of discovered index with the elements in the original list. Elements with assumed idex of -1 will rerurn null value, thus nothing will be paired… Try it.
Once I started working, | realized its not that simple. The ends of tree beams could intersect at one spot. Therefore, I recommend a different approach.
I determined all axis of beams by using Planes. It is the only infinite geometry in Dynamo that I know of. Z values of points in conjunction with the Planes determined the axis. I grouped all the beams per each axis. Then, I used “group curves” node to group the beams by joinable curves.
