How to extract length of a curve using python code
i would like to extract length of a pipe using python code. I don’t know how to use properties of a class. I wrote as shown below.
clr.AddReference(‘RevitApi’)
#from Autodesk.Revit.DB.HostedSweep import *
from RevitServices.Persistence import *
from RevitServices.Transactions import *
sel = uidoc.Selection.GetElementIds()
stlist=
endlist=
length =
for i in sel:
item = (doc.GetElement(i))
loc = item.Location
len = item.Length
start = item.Location.Curve.GetEndPoint(0)
end = item.Location.Curve.GetEndPoint(1)
stlist.append(start)
endlist.append(end)
length.append(len)
OUT =stlist,endlist,length
Use LookupParameter to get the parameter by name.
http://www.revitapidocs.com/2018.1/4400b9f8-3787-0947-5113-2522ff5e5de2.htm
Can you show what error you are getting? Just off the script you’ve shown, shouldn’t the import for clr.AddReference(“RevitApi”) be “RevitAPI”, because it should be case sensitive.
I corrected as below. now its working.
