how to create a curve from line by python.
Thank you very much.
Thank you so much
Hello I tried this python script as I want to convert a list of lines and sublists into a curve list, but this works only with flatten list of lines. I think it is easy solution if you have an answer would be great. Thanks.
Although I tried to offset curve with no offset, as the python code, it sounds silly solution, but is this an appropriate way to get the list of lines transformed into curves list?
Hi @RubenVivancos the python made by @fluffyhugger is for @L2 list level, you have modify the python or create a custom node for work with different level list.
Cheers
is possible to get lines from curves? opposite operation
Curve.PointAtParameter(c,0) = StartPoint
Curve.PointAtParameter(c,1) = EndPoint
line = Line.ByStartAndEndPoint(StartPoint,EndPoint)
@fluffyhugger that script seems to be returning Lines when fed a flattened list of Lines.
same here… the offset trick doesn’t work anymore in Dynamo 2.12.
some methods in the Revit API only accept Curves not Lines (FamilyCreate.NewModelCurve in my case)
I face the same issue
