How to get Assembly Code parameter value from element?
Hi all,
I’m trying to solve a problem in my dynamo work. I must create a parameter that name is “BIM TASK ID”. It’s combination of a few parameters, builging name, phase, level etc. I’m trying to add “assembly code” of elements to my ID but I can’t get assembly code of elements. How can I solve it? Thanks in advance. 1
Would like to know how to do this in python!
Hi, may i ask you please what kind of packages are you using in this script?
I avoid packages as they shift, break and change functionality too much.
Python is built into Dynamo- this was probably 1.x .
