How to get data from material take off Elements Precast
How to get parameter (length, width, mass, etc) in solid wall elements
Element.GetParameterValueByName is not working
@bektikristiajiHW66S ,
Thats the way to snoop out your elements
KR
Andreas
Hello, here is a possibility
edit: I had forgotten the codeblock with the conditionals to filter the necessary elements
a="Part";
b="AssemblyInstance";
Cond_1=result_Part==a?true:false;
Cond_2=result_AssemblyInstance==b?true:false;
[Cond_1,Cond_2];
Curiosity:
The installation of the French Precast library (made me switch the dynamo language to English, for information)
Cordially
christian.stan
Thank for your answer @Draxl_Andreas , but the node not working for my elements
My element isn’t familes , but assemblies.
How to get data assemblies in my element?
Thankyou @christian.stan the answer.
But my element isn’t working if we run with node “Element.Parameter” or “GetParameterValueByName”
Any alternative solution for my problem?
hello, connect your wires to the out of your filter (your assembly instance is there for you)
Cordially
christian.stan
Wow…
the node working at now.
