hi
in “Set Type Parameter” node you have connect the value of the parameter as a “Element " input
you have connect it from the " All Element Of Category” node
i dont get it why do you divide the value of parameter with string values. this with get you null value
what are you trying to get , i may help you
i just want to update type parameter of wall named “Assembly Code”
Hi, where I can get the node “Get Type Parameter”, I try to get parameter “assembly code” as well. May i ask you please what kind of packages are you using in this script?
