How to get a room curve
I use LunchBox Room Element Collector node. However, an empty list is displayed. What models are needed before running the node?
use the following nodes and connect them
1 select model element
2 room.FinishBoundary
3 Polycurve.ByjoinedCurves
or
1 your Lunchbox room element collector and connect Element to the input port of the Room.FinishBoundary
I tried it, it is very good
mark the post as solved
Is that so? I am getting started
Yes
for other users with the same question in the future, the solution can be found faster
