How to get a Dynamo Category from a DB Category?
Im learning more about how to use python. I have this issue, what method would I use to get the Revit.Elements.Category from a Revit.DB.BuiltInCategory? I have tried looking at some nodes- whenever I try to get the Id from the DB.Category, it throws errors. Thanks in advance!
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
# Current doc/app/ui
app = uiapp.Application
#CODE___________________________________________________
OUT = BuiltInCategory.OST_Walls
Try type conversion by name
# Category name from Revit BuiltInCategory
revitcatname = Category.GetCategory(doc, BuiltInCategory.OST_Walls).Name
# Dynamo type
dynamocategory = Revit.Elements.Category.ByName(revitcatname)
Yes that works! And I consequently learned I could just use the string in most scenarios, thanks! I ended up collapsing it down into one statement just for practice-
OUT = Revit.Elements.Category.ByName(Category.GetCategory(doc, BuiltInCategory.OST_Walls).Name)
Even easier:
OUT = Revit.Elements.Category.ById(BuiltInCategory.OST_Walls)
