Get all BuiltInCategory - ERROR
Very good days.
I have the following problem.
I am trying to get all the categories of the currently open file and then I want to get its items.
It happens that I can’t get past the line to obtain the categories by ID and I always get the error as you can see…
I’m doing wrong…
Thanks for your help.
Python script.dyn (3.4 KB)
@AM3D.BIM.STUDIO ,
try this:
# 📦 imports
import sys
sets = doc.Settings.Categories
# 🎯 gets all categories in the document
allCats = doc.Settings.Categories
OUT = allCats
i used R2024, but IronPython3 … CPython is still not working.
you mean in current View? 2D and 3D and views ?
KR
Andreas
@AM3D.BIM.STUDIO ,
i can share this it runs on PyRevit pretty well!
items = FilteredElementCollector(doc, doc.ActiveView.Id).WhereElementIsNotElementType().ToElements()
print('\n There are {} Elements'.format(len(items)))
# Prepare dict with an empty List as default value
from collections import defaultdict
dict_elements = defaultdict(list)
for i in items:
    try:
        cat_name = i.Category.Name
        str_built_cat = str(i.Category.Name)
        dict_elements[str_built_cat].append(i)
    except:
        print('Element ({}) does not have BuiltInCategory!'.format(i.Id))
        # You might get 1-2 elements without Category!
# Show Results
print('\n List number of element in each category')
for k,v in dict_elements.items():
    dist = 30 - len(k) # Calculate ammount of dashes to print nicely
    print('{}:{} {} Elements'.format(k, '-'*dist, len(v)))
you can modify it to dynamo
KR
Andreas
Thanks for your comment…
Sorry I forgot to mention that I am working within REVIT 2020, I thought it was the same for all versions and now researching I found the surprise that it is different in REVIT 2020
any idea what it could be like in the 2020 version
This will work with R2020
import sys
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import BuiltInCategory
all_cats = doc.Settings.Categories
builtin_cats = [cat for cat in all_cats if cat.IsBuiltInCategoryValid]
all_bics = System.Enum.GetValues(BuiltInCategory)
OUT = all_cats, builtin_cats, all_bics
for all version of Revit
import sys
import System
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
if sdkNumber > 2022:
    builtin_cats = [cat.BuiltInCategory if cat.IsBuiltInCategoryValid else None  for cat in all_cats ]
    builtin_cats = [System.Enum.ToObject(BuiltInCategory, cat.Id.IntegerValue) if cat.IsBuiltInCategoryValid else None  for cat in all_cats ]
OUT = builtin_cats
