How to get the Category Name - API Name?
i can get the name of a category. But how can i get the API Name like OST_Rooms, OST_Slabs, OST_StructuralColumn, … a.s.o. ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
items = FilteredElementCollector(doc, doc.ActiveView.Id).WhereElementIsNotElementType().ToElements()
# Prepare dict with an empty List as default value
from collections import defaultdict
dict_elements = defaultdict(list)
for i in items:
    try:
        cat_name = i.Category.Name
        dict_elements[cat_name].append(i)
    except:
        pass
        # You might get 1-2 elements without Category!
# Show Results
result =  [k for k in dict_elements.items()]
OUT = result
element = UnwrapElement(IN[0])
APICategory = [i.get_Parameter(BuiltInParameter.ELEM_CATEGORY_PARAM).AsValueString() for i in element]
OUT = APICategory
I highly recommend installing the Revit Lookup tool to help with things like this. It’s way easier to just look for the stuff you’re after than go searching on the internet.
See my post here How get OST (Built-In Name) of element - #23 by Mike.Buttery
How I would do it now
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import BuiltInCategory
OUT = System.Enum.GetName(BuiltInCategory, IN[0].Id)
EDIT IN[0] is a Dynamo Category object
This should cover almost anything with a category
import System
from Autodesk.Revit.DB import BuiltInCategory, Category
inputs = UnwrapElement(IN)
ids = [
    i.Id
    if isinstance(i.Id, int)  # Dynamo Category
    else i.Id.IntegerValue
    if isinstance(i, Category)  # Revit Category
    else i.Category.Id.IntegerValue  # Revit/Dynamo Element
    for i in inputs
OUT = [System.Enum.GetName(BuiltInCategory, id) for id in ids]
@Nick_Boyts ,
i got a empty list when i use BuiltInParameter
KR
Andreas
i understand i need category itself …
i have to combine it with python-dicctionary
i can run it in this way…
KR
Andreas
The property is only available in 2023+. I believe it still requires you to check for the matching Id, but it’s a bit of a shortcut.
You could just do this in your code rather than getting the category separately.
