I have some Issues with the Parametertype while creating a Projectparameter. Why is “Integer” an invalid Parametertype? I also tried the Select Parameter Type function, but it ends in the same Issues. I was already searching for this situation but couldn’t get some answer.
@Mark.Ackerley, @Marcel_Rijsmus, @erfajo
Thank you a lot for your answers. I changed the group name and it obviously works now. I couldn’t change the projectparametername cause I need it for other scripts. With Autodesk Dynamo I create schedules and then add the unique ElementID to them. I know that there is an internal parameter with the same name. I use my parameter to reference on the internal parameter.
Here is the other script:
I found this both parts in some forum posts. I will link them for the cause I find them. You maybe know some solutions, but I don’t want to waste your time.
