I am currently learning dynamo and I I am trying to add parameters from an Excel file to a project. I am stuck at this point from an error that does not appear in the tutorial I am following along.
Is there a way out of thus?
Is the tutorial you are following in the same version of Dynamo that you are working in now?
A while ago I had the same problem and found this post on the autodesk website. It should be resolved in version 2023.1 and 2024. Integer type parameter value cannot be changed in Dynamo for Revit 2023
