How to find coordinates and make grid at edges using dynamo
hi.
i am new to dynamo. i want to find the coordinates at these intersection points using dynamo.
at this moment i have drawn this grid manually but is it possible that through dynamo i can draw this and find these coordinates at intersections? if yes then how?
thanks in advance!
Capture|690x447
fil.rvt (4.0 MB)
A simple search for “grid intersection” in the forum will give you a good starting point.
Another search for “coordinates at point” should get you the rest of the way.
If you get stuck, then posting your graph and what you’re stuck on will get you more assistance and faster.
This might solve your issue;
It will find grid intersections and also label elements by their closest intersection.
