hi. is there any way to find coordinates at these points in dynamo?
i want to find coordinate 6ft away from the bottom edge.
It’s the same concept like I showed you on top. You just need to add Geometry.Translate node to translate bottom edge on Vector Y Axis with 6’ distance.
can you share the dynamo script?
Can you share relevant rvt file.
fil.rvt (4.0 MB)
actually, i want to find coordinates at 6 feet from each edge line at level 2. is that possible?
package for element. type?
