How to extract points of intersection lines from a Block References to drawing
Hello all
Is anyone helping me?
How do I extract the intersection points from the block so that I can create a civil point from it?
b1
MTEST TO COGO POINTS LINES 0011 .dyn (51.4 KB)
b1.dwg (1001.0 KB)
Would the insertion point of the block help in this case?
@Assem.Daaboul
If the insertion point of the block is different than point of intersection of the lines
The point of intersection of the lines is needed to form a point civil 3d again
Thank you
Yeah, this might happen. So you were getting the original block objects which seem to be at 0,0,0. in your case, you may need to explode the blocks to get the correct location of the exploded block elements and get the intersection.
hi @Assem.Daaboul
Is it possible to attach the dynamo file?
Because the picture is not clear to me
to try the file
Thank you
Here it is.
MTEST TO COGO POINTS LINES 0011 .dyn (86.8 KB)
@Assem.Daaboul
Thank you
