BlockReference insertion point coordinates
Good Evening , some output data that is very useful is to get the global coordinates (X,Y,Z) of the BlockReference’s insertion point in an existing drawing in global coordinates.
Does any node or workflow that get this output?
getallobjecttypes ( blockReferencies) in Document►¿InsertionPoint.BlockReference node/workflow?
Thank you a lot!
@javiermend
which is the same topic here, you need to understand Dynamo CoordinateSystem.
In order to complet this post.
CoordinateSystem nodes is something abstract that the more you use the more sense makes you.
Still learning!
Hello everyone,
I wonder if it is easily possible to modify the insertion Point of a gien blockreference?
Thanks a lot
