I have a set o curves and lines that I create on Dynamo that I’d like to use on Revit. I have tried running Dynamo player, using the ImportInstance’s byGeometry and exporting to .SAT then importing back into Revit. But none of these solutions seem to work. Is the issue that I am exporting lines and curves instead of solids? If so, how could I export them out of Dynamo.
If you would want to have them in Revit as curve elements, perhaps ModelCurve.ByCurve would work?
As Jacob mentioned you can use ModelCurve.ByCurve to convert the dynamo lines into Revit Lines and here’s a snip
Accordingly, you can pick for your workflow. i hope it resolves your Query but in case you wish to do something else do elaborate.
Regards,
BM
