How to create multi-segment aligned dimension in Dynamo with python?
I have been looking geniousloci Dimension ByReferences but I am not sure if this is creating just individual dimensions or multiple in a single dimension element in a view.
For example I created Aligned dimension of 5 segments manually, but I would like to achieve the same result with script. I see by using snoop object tool plugin that reference is ReferenceArray and Segments is DimensionSegmentArray.
#Alban de Chasteigner 2019
#twitter : @geniusloci_bim
#geniusloci.bim@gmail.com
clr.AddReference('RevitAPI')
def tolist(obj1):
    if hasattr(obj1,"__iter__"): return obj1
    else: return [obj1]
view = tolist(UnwrapElement(IN[0]))[0]
lines = tolist(IN[1])
references= IN[2]
dimensionType=tolist(UnwrapElement(IN[3]))[0]
elementsRef = ReferenceArray()
for reference in references :
	elementsRef.Append(reference)
for line in lines:
	if doc.IsFamilyDocument == True :
		if IN[3]== None:
			dim = doc.FamilyCreate.NewDimension(view, line.ToRevitType(), elementsRef).ToDSType(True)
			dim = doc.FamilyCreate.NewDimension(view, line.ToRevitType(), elementsRef,dimensionType).ToDSType(True)
		if IN[3]== None:
			dim = doc.Create.NewDimension(view, line.ToRevitType(), elementsRef).ToDSType(True)
			dim = doc.Create.NewDimension(view, line.ToRevitType(), elementsRef,dimensionType).ToDSType(True)
OUT=dim
The dimensions are created based on the grouping of the references. So if you have more than (2) references in the group, the dimension string will be one multi-segment string and not two individual strings.
