simple task: I have two different type of levels. but there isn’t a node in dynamo that add levels by type, only by elevation or name or both. my second type of level uses different level heads etc. How do I mass create levels but assign some of them to a different level type?
Have you attempted to set the type after creating them in Dynamo?
I tried the Family Types node, where you can select a type in a drop down menu, but the level type isn’t there. Are level types (system family) accessed differently?
I tried to do this but of course level is not a family instance. Output is null
Is there a node that can do what I need to do?
I can certainly manually set them but they are vast in number. I wondered if there is a way in dynamo to do them all at once
Hi @visualizor,
I have the same problem with “gridlines”.
When i have a project with a lot gridlines i can’t seem to figure out how to set them to the desired GridType
I hope someone can solve this.
Kind regards,
Mark
Looks like you might have to use Python.
http://www.revitapidocs.com/2018/479b5d94-abd3-db42-27d7-6a3eda12f285.htm
