how can i get volume from that?
and more how can i make a union of this solids?
At this point you have a Revit solid, not a Dynamo one. As a result you will need to stay in the Python node.
The methods you can call can be exposed in a few ways:
OUT = dir(solids[0]).import inspect
OUT = inspect.getmembers(solids[0])
Using those three methods, you can likely find that solids have a Volume property, which can be called by using some list comprehension, something like this:
OUT = [s.Volume for a in solids]
Note that I can’t confirm as I am running some errands.
once you use “solid.ToProtoType()” it will convert the geometry to dynamo geometry…try to avoid that
@newshunhk @c.poupin @jacob.small ,
Can i also set union of these Autodesk.Revit.DB.Solid in the code?
like Autodesk.Revit.DB.Solid.ByUnion
Hi, you can use
i try first just merge 2 walls, without success
how do i set union all solids XXX ?
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
element1 = UnwrapElement(IN[0])
element2 = UnwrapElement(IN[1])
solidA = element1.get_Geometry(Options())
s1 = solidA.Solid
solidB = element2.get_Geometry(Options())
solidintersections = BooleanOperationsUtils.ExecuteBooleanOperation(solidA, solidB, BooleanOperationsType.Intersect)
mass = solidintersections.Volume
OUT = solidintersections, mass
Here an example
import sys
import System
collectorColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns)
placedColumns = collectorColumns.WhereElementIsNotElementType().ToElements()
lst_Geo = []
opt = Options()
for i in placedColumns:
# get Solid with volume > 0
geoset = i.get_Geometry(opt)
for geo in geoset:
if isinstance(geo, DB.Solid) and geo.Volume > 0:
lst_Geo.append(geo)
elif isinstance(geo, DB.GeometryInstance):
for geoi in geo.GetInstanceGeometry():
if isinstance(geoi, DB.Solid) and geoi.Volume > 0:
lst_Geo.append(geoi)
global_solid = lst_Geo.pop(0)
for s in lst_Geo:
global_solid = BooleanOperationsUtils.ExecuteBooleanOperation(global_solid, s, BooleanOperationsType.Union)
OUT = global_solid, global_solid.Volume, global_solid.ComputeCentroid().ToPoint()
Hi, what is your output from this in Dynamo, does it return DB.Solids?
PS: Why don’t you try the JoinGeometry class as mentioned in this topic: Join solids in Revit API
What is your end goal actually? Do you need to get the exact geometry of the difference between both sets of columns or only check if there is a difference? If it is the latter, you could try getting the sums of volumes for both sets of columns, using the Solid.Volume property. If both sums are equal in the end, there is no difference ![]()
i want to make a model compare indepented from categories! So i want the pure Concrete geometry (Asbuild) i want to compare the volumes to get a real diference!
because in constructuion field there is no slab, beam or wall… …there is just concrete
