Hi, all!
I am trying to get Rooms’ geometry through the API. I am currently getting the geometry successfully as Revit API elements:
Here’s the code:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
app = uiapp.Application
rooms = UnwrapElement(IN[0])
outlist = []
for room in rooms:
outlist.append(room.Geometry)
outlist.append(room.ClosedShell)
OUT = outlist
However, once I try to wrap them, I get the following warning:
It works neither with ToDSType, nor with ToProtoType methods:
Normally, ToProtoType() should work when revit geometry is concerned, at least according to this: Python 0.6.3 to 0.7.x Migration · DynamoDS/Dynamo Wiki · GitHub
Please help
I found the solution:
import sys
import System
outlist = []
options = SpatialElementBoundaryOptions()
options.SpatialElementBoundaryLocation = SpatialElementBoundaryLocation.Finish
calculator = SpatialElementGeometryCalculator(doc)
for room in rooms:
solid = calculator.CalculateSpatialElementGeometry(room).GetGeometry()
outlist.append(solid.ToProtoType())
OUT = outlist
Seems like my method of obtaining the solid was wrong
It also works fine if you append the individual faces:
import sys
import System
outlist = []
for room in rooms:
for face in solid.Faces:
outlist.append(face.ToProtoType())
OUT = outlist
Hope someone finds this usefull
