Join solids in Revit API
Hi community,
I want to join solids with the revit API
I dont know which method is the right one. JoinGeometry?
It should work out as the solid.ByUnion in Dynamo nodes, but with the revit API, I dont want to use the solid.ByUnion cause the conversions and to use Dynamo nodes consume a lot of time (I tried out already and the code get really slow)
thanks in advance
Hi @igpema
JoinGeometry expects Revit elements, not geometries.
yes Mostafa, I got this error in python, but is there a way to join solids with the revit API?
thanks
Not really sure I understand what you want to do. Join geometries in Dynamo? Or in Revit?
hi Mostafa,
i want to join solids in Dynamo with the revit API and not with the Dynamo Nodes solid.ByUnion. The solids are for a clash detection. If there is not a method for that in the API, i will find other way :slight_smile:
thanks in advance
Does this move you on at all?
http://www.revitapidocs.com/2018/17966565-84c8-9dc3-dc0d-62cb6c896624.htm
Cheers,
Mark
yes thanks Mark, i try out tomorrow, it should work out actually :slight_smile:
