What have you tried so far?
Have you done a search of the forum?
I would suggest reading the FAQ to assist with getting better responses How to get help on the Dynamo forums
import sys
import System
from System.Collections.Generic import List, IList, Dictionary, HashSet
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
import math
def loop_from_pts(lst_ds_pts):
# flat list points
lst_ds_pts = [DS.Point.ByCoordinates(p.X, p.Y, 0) for p in lst_ds_pts]
avg_x = sum(p.X for p in lst_ds_pts) / len(lst_ds_pts)
avg_y = sum(p.Y for p in lst_ds_pts) / len(lst_ds_pts)
# sort by vectors angle from X
get_angle_fromX = lambda point : math.atan2(point.Y - avg_y, point.X - avg_x)
sorted_points = sorted(lst_ds_pts, key=get_angle_fromX)
polycurve = PolyCurve.ByPoints(sorted_points, True)
lst_curve = List[DB.Curve]([c.ToRevitType() for c in polycurve.Curves() ])
curve_loop = CurveLoop.Create(lst_curve)
return curve_loop
lst_ds_pts = IN[0]
lst_xyz_pts = [p.ToRevitType() for p in lst_ds_pts ]
floor_type = UnwrapElement(IN[1])
level = UnwrapElement(IN[2])
curv_loop = loop_from_pts(lst_ds_pts)
TransactionManager.Instance.ForceCloseTransaction()
t1 = Transaction(doc, "t1")
t1.Start()
floor = Floor.Create(doc, List[CurveLoop]([curv_loop]), floor_type.Id, level.Id)
doc.Regenerate()
slabShapeEditor = floor.GetSlabShapeEditor()
slabShapeEditor.Enable()
t1.Commit()
t2 = Transaction(doc, "t2")
t2.Start()
for v in slabShapeEditor.SlabShapeVertices:
v : SlabShapeVertex
print(v.Position.X)
input_rvt_pt = next((p for p in lst_xyz_pts\
if abs(p.X - v.Position.X) < 0.01 and abs(p.Y - v.Position.Y) < 0.01),
None)
if input_rvt_pt:
slabShapeEditor.ModifySubElement(v, input_rvt_pt.Z - v.Position.Z)
t2.Commit()
OUT = floor
