How to create a Bounding Box around multiple elements
Hi
I have a list of Revit elements and I would to create a single Bounding Box around all elements in my list.
Could you please let me know how to that?
I do appreciate your help in advance.
Regards,
Farshid
Geometry has nodes for singular and multiple geometries. You can convert your elements to geometry and use that instead.
# Import Namespace References
import clr,sys
# Revit API
clr.AddReference('RevitAPI')
# Flatten a source list
def flat(source):
    result = []
    def flatten_sequence(seq):
        for item in seq:
            if isinstance(item, (list, tuple, set)) and not isinstance(item, str):
                flatten_sequence(item)
                result.append(item)
    flatten_sequence(source)
    return result
# Create a bounding box around multiple elements
def multi_element_bbox(elements):
    point_list= []
    for e in elements:
        element_bbox= e.BoundingBox
        point_list.append(element_bbox.MinPoint)
        point_list.append(element_bbox.MaxPoint)
        flattend_point_list = flat(point_list)
        return BoundingBox.ByGeometry(plist)
OUT = multi_element_bbox(IN[0])
Collect the min and max points of each elements bounding box and use the points to create a new bounding box. If you want alignment to ‘best fit’ the bounding box to the geometry itself then you will need to use a slightly different approach.
Non-Aligned
Aligned
Multi Element Bounding Box and Aligned Bounding Box.dyn (43.2 KB)
