I am trying to take multiple faces in revit and convert to dynamo geometry, but the element.geometry node does not accept multiple entries. Is there a node that does multiple.
If you are using multiple Select Face nodes, then try creating a list with List.Create and then input that into the Element.Geometry.
Perhaps the ‘Select Model Elements’ node is a better entry point for your effort?
