@Mohammadz @Mostafa_El_Ayoubi I’m already get path coordinate in excel, how to create sweep soild
- Generate points from the XYZ values you’ve brought into Dynamo using a Point.ByCoordinates node.
- Create a nurbs curve from the list of points using a NurbsCurve.ByPoints node.
- Find the plane at parameter 0 for the nurbs curve with a Curve.PlaneAtParameter node.
- Get the coordinate system of that plane with a Plane.CoordinateSystem node.
- Draw the profile you want to sweep along the path at the origin and using the XY plane as your sketching surface, using whatever method is right for your project (ie: Rectangle, a circle, a polygon by point… whatever shape you need).
- Transform the profile onto the coordinate system using a Geometry.Transform node.
- Use a Solid.BySweep node to sweep the profile along the path.
@jacob.small Any referance file is available , Please send
Thank you
Nothing offhand. I don’t have an excel file with points to generate a path or a defined profile either.
What have you tried?
@jacob.small
i tried to create this script. But, not working. could you help me resolve this?
Create sweep from excel.dyn (33.2 KB)
Dynomo Input.xlsx (21.6 KB)
@christian.stan how to use circle profile
thanks, but i am going to run circle only along the path, in that situation how can i assign center point
Sweep along the path is Not working.Please check and find the attachment.
sweep based on excel.dyn (38.3 KB)
Dynomo Input.xlsx (12.3 KB)
you made a mistake in the path, you sent a plan instead of the curve support
Cordially
christian.stan
Looks like you are passing a plane into the path rather than a curve.
Can’t read the graph - export it as an image after zooming in.
By graph I was referring to the screenshots showing your nodes on the Dynamo canvas. The first image in your post.
Did you duplicate your Dynamo entity as a Revit entity
Cordially
christian.stan
