Hi everyone ! I’m creating a script to convert areas into rooms, the way it works is selecting all of the areas modeled in the project, selecting the correct ones by filtering them using a parameter created by me (OPTION_SURFACE), then getting the location, level and name of those areas and afterwards creating the rooms using the node Room.ByLocation.
All of that works great! BUT, I want to make it easier for the users at my office to run the script by creating a UI that ask them to simply select the correct OPTION_SURFACE and it’s done.
The issue is that the result of the User Input is a list instead of a string, which is what I’m using to filter the areas.
Is there a way to convert the list given by the User Input to a string acceptable by my filtering nodes? or, is there a better way to filter my areas that would accept the result given by the User Input?.. I hope what I’m asking makes sense, I tryed looking online, but I couldn’t find an answer anywhere.
Here is the complete script in case it helps.
Thank you beforehand for all of your help.
