Hi everyone,
I’m trying to calculate the kilometer (stationing) of modeled elements along a axis using Dynamo.
Here is what I have:
I already have a working script that extracts element coordinates and exports them to Excel.
I know the coordinates of two reference points:
Point A → KM 13,5
Point B → KM 17,5
I want to compute the kilometer value of each object by projecting its coordinate onto the axis vector between those two points.
The geometry and coordinates are taken from Revit elements, and the base point can be hardcoded.
What is the best way to do this projection in Dynamo?
Would this do what you need as it gives you a distance between two points.
Hi @Sabine_weber ,
You have two options:
Use Dynamo for Revit to access Civil 3D objects and get the station of any Revit element based on the alignment in Civil 3D.
You can use the BriMohareb package for this.
for the base point coordiantion transform the revit location to the C3d location by use this node
Project the location of the Revit element onto the polyline (axis); the output will be the station parameter.**
This packedge use Dynamo Revit_2023 as plateform to integrating Revit_23, Civil3d_23 , Autocad, sofistik_2018, sofistik_2023 and Add extra geometry nodes to dynamo through API. It help bridge and tunnel engineers to create and Automate automate model and design.
Also makes it possible to create complex bridge and tunnel elements by using Adaptive family
[image]
