Hello everyone! I’m tryng to figure out how to calculate the area of different types of floor present in my project.
Once I got two separated lists of the different types of floor and the correnspondents areas, i don’t know how get the total area for each type of floor.
Thanks for your help!!
you can use a Math.Sum node
It is not just about calculating the total area of all floor types but to calculate the total area for any type present in the project (red square).
That’s illuminating!! Just one more question, I cannot find the Elements.Type node is in some custom package?
Thanks a lot
Yes, Elements.Type is in Archilab package, but you can use the OOTB Element.ElementType :
http://dictionary.dynamobim.com/#/Revit/Elements/Element/Query/ElementType
If you are using Dynamo 1.3 you can also use FamilyInstance.Type
Glad to be helpful, don’t forget to mark the topic as solved
I’m sorry but i still cannot find no one of these nodes ( Elements.Type, Element.ElementType, FamilyInstance.Type) no one of them is in pre installed nodes in Dynamo and in Archi-lab neither
Which version are you using?
2.0.2, there should be something wrong!
