Hi everyone,
I am wondering, how I can assign to intersect geometry, floors and walls, parameter top offset which is assign to walls by floors which them are crossing. If you know what I mean .
I stuck in this point, I have geometry floors and walls, them are intersect and what then, how take walls and assign them top offset, dependend of floors thickness which is crossing with ?
Little update: now I have all floors witch matched walls which they are intersecting each other. Now if someone know how to do it, I need to take parameters of top offset from this walls.
Use GetParameterValueByName to get the ‘Base Constraint’ and ‘Base Offset’ of the floor and use SetParameterValueByName to set the ‘Top Constraint’ and ‘Top Offset’ parameters of the wall.
I would use AnyTrue node applied to level 2 after Geometry.DoesIntersect and then apply this list to FilterByBoolMask node to get a direct list of the original elements, not the solids this way you would also get rid of those warnings that you get because of the -1 index.
Afterwards, you could easily use what @Alien suggested. If you are still struggling, you could provide the graph, along with a small sample file and we can fix it for you
@krzysiektoja just a small heads up… casting to Dynamo geometry to check if elements intersect can be made much faster if you dont cast it to dynamo geometry but use nodes that test only for element intersection…
I made this post where I filter for intersecting elements before I make the actual provision void, maybe that can inspire you.
Thanks for that I really want to do it but I have some trouble to instal Orchid because I work on Revit 2019 witch Dynamo 2.0.3 and the nodes are missing.
In task, now I have all right but I want more and try add to walls solids, top offset to make sure that intersecting with floors and I have completed rest of script.
I see…
That is a problem, I maintain the last four versions but that does not include Revit 2019
I am running my project alone and I have probably the largest package for Dynamo and that is maintained pr. version which is quite challenging due to the enormous amount of new requirements in the Revit API over the last couple of years… Not that is a problem and certainly not that Revit should stop developing… but you need to take care of the different versions. On top of this is the Dynamo API also being developed quite a bit and thanks for that… lastly I also cover the IFC exporter, and again IFC is developing.
I am never getting bored
Could you somehow move to Revit 2020, then I can assist you
Basically, you just get all surfaces of the solid, find the bottom one, get its perimeter curves as a polycurve and extrude it back as solid, based on the sum height.
