How to add cant to rail alignment from excel using Dynamo in civil 3d
Hi, Could not find a dynamo node to import rail cant to rail alignment in dynamo. how to add cant to rail alignment from excel using Dynamo in civil 3d.
Hi @Shudhir.Gopinathan,
There isn’t a single node that will do this, so it would need to be a combination. If you can download Civil 3D 2025.1, there are several nodes for adding cant critical stations and setting their parameters.
Hi @zachri.jensen ,
Are these nodes avalaibles in C3D 2024?
No, they are only available starting in Civil 3D 2025.1.
Anyway to adress it with python code in 2024?
Sure, these are the relevant APIs:
