How I can align grids?
Transaction open
set.Grids.Curve.Point.X ?? or something like that
I need I need the syntax.
or where to look?
Transaction close
Thank you
grids_position
You could just assign them all to a scope box in Revit, then unassign and stretch to where you need.
Grid2Scope
John, thank you
But I would like to solve this problem through Python and RevitApi
I do not know where to find an example of an appropriate syntax Python for set parameters grids position (start point)
Read-only or am I doing something wrong
why is it not working?
I would like move the grid to the line
12
Legantmar,
You will not be able to change the reference curve or the start/end point of the curve.
What you can do though is move these curves: http://dynamobim.com/forums/topic/dynamo-to-relocate-placed-family-in-revit-file/
Thomas
Revit 2016 exposed a few new methods for grids and levels’ representation. You might be able to find something that can align grids in here( check out “DatumPlane.SetCurveInView()” in particular):
Thank you, Thomas and Dimitar!
You helped.
example code for move one grid:
grid = UnwrapElement(IN[0])
ids = ListElementId
ids.Add(grid.Id)
vector = IN[1].ToXyz(True)
ElementTransformUtils.MoveElements(doc,ids,vector)
