Checking the civil 3d forum I saw this code and I would like to know how python can be edited according to lei is to be able to modify the radii of the alignment
Foro civil 3d
foreach (var entity in myALignment.Entities)
if (entity.EntityType == AlignmentEntityType.Arc)
var arc = (AlignmentArc)entity;
arc.Radius = 100;
else if (entity.EntityType == AlignmentEntityType.Spiral)
// cast and modify
probably this,
you may miss some import
for entity in myALignment.Entities:
if entity.EntityType == AlignmentEntityType.Arc:
arc.Radius = 100
if entity.EntityType == AlignmentEntityType.Spiral:
# cast and modify
pass #or do something
I tried to apply it to the alignment but I don’t see that it modifies the radius
What would have to be changed to the code?
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
arc.Radius = 100
# cast and modify
OUT = 0
